Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: JD 50 Electronic Ignition Coil Temp.
01-15-2013 05:41:48
Or measure the primary dc resistance (may be easier) which should be adequate to privide the 4-5 amperes that you want for your transistor switch to conduct. Taking a nominal 12v and 4 amps you need at least 3 ohms of dc resistance between the power applied from the ignition switch and the coil terminal that goes to the electronic ignition module. If you don't have it, get a ballast resistor in the circuit that will get you there.
Did you get instructions for installation, like a note that says that an xyz ohm ballast resistor is required with this coil?
Some ign. modules warn you that if you over current the circuit, which you seem to be doing, you can kill the module due to overheating the switching transistor.
01-15-2013 15:23:16
 Re: JD 50 Electronic Ignition Coil Temp. in reply to Texasmark1, 01-15-2013 05:41:48
Now the rest of the story! So I learn this history today, the tractor hasn't been run much in 8 - 10 years. They never could keep it going for long, now I find out (with you fellows help) someone back "then" rewired the tractor - without the resistor! Now to replace it--- any suggestions? What would work that I can get from the auto parts store?
01-16-2013 05:44:39
 Re: JD 50 Electronic Ignition Coil Temp. in reply to HobbySaw, 01-15-2013 15:23:16
Over the years I have needed resistors and purchased them from NAPA auto stores. Main thing is that it is made for the occasion with some being one value like 1.5 ohms or thereabouts, and others with taps where you could add resistance to get what you want. Then they are mounted on white ceramic bases to insulate them from their mounting since they get hot with 2 holes for mounting.
01-15-2013 16:12:04
Does the starter switch have the terminal for bypass starting. Don't let anybody tell you that there really is a resistor inside some coils. Do you want a tractor with bypass starting?
