Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: JD model B white vapor from around clutch
[Return to Forum]
Jim Skala
01-14-2013 15:43:02
199.209.144.211
When running slow with a few misses, I see a white vapor coming from around the clutch. I also see this if I am running fast and shut down by deactivating the magneto -- I see lots of it then. I don't smell anything in the vapor (white smoke that dissipates in air). I'm wondering if it could be fuel vapor that got into the crankcase. Does this indicate that the seal between the crankcase and the clutch is blown? It is possible that the crankcase vent back to the air intake is plugged?
[Reply]   [No Email]
Lee B
01-14-2013 23:53:07
64.37.30.36
 Re: JD model B white vapor from around clutch in reply to Jim Skala, 01-14-2013 15:43:02
There is no seal to blow or replace between engine and clutch opening. If you don't smell gas it's not fuel - it has to be water. It's more likely that you are making so much water vapor as to overload any ventilation scheme the tractor is using. But the vent could be plugged too, what's it cost to check?
[Reply]  [No Email]
bigboreG
01-14-2013 16:36:48
166.181.3.11
Could possibly be moisture in oil? Does the tractor sit quite a bit? What year is it by the way? Sounds like its building crankcase pressure and if its too old to have a ventilator pump, then the engine is probably worn, and the stuff your seeing is blowby. My '42 B had blowby, a good hone and a set of new rings cured that. I also did a valve job and rebuilt the carb at the same time.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
