Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: JD 50 Electronic Ignition Coil Temp.
[Return to Forum]
HobbySaw
01-14-2013 15:23:20
98.88.14.49
Just installed an electronic ignition conversion with Flame Thrower ignition coil on a friends 1956 50. Tractor runs great but the coil seems very hot to the touch. Do these epoxy filled coils normally run hotter than original point coils? Scared to put her to work until I find out what to expect. Other info- 12 Volt positive ground system (correct kit), new voltage regulator installed charges at 12v at idle up to 14.5 at full throttle. Same battery as before, still checks good. Thanks
[Reply]   [No Email]
HobbySaw
01-24-2013 17:32:47
98.88.14.49
Re: JD 50 Electronic Ignition Coil Temp. in reply to HobbySaw, 01-14-2013 15:23:20
Sorry for the late reply, been busy elsewhere. Here"s what we have now. Ignition resistor from an auto parts place, no idea of the resistance but tractor runs great with about 7-8 volts on the coil once all warms up. The coil now runs cooler than the generator (about 130F). All seems good to go. Thanks for the help
  [Reply]  [No Email]
2-banger
01-22-2013 17:51:44
69.205.113.95
i run them on my 50..60..a and g..u need a 3.0 ohm coil with internal resistor you probaly got a 1.5 ohm and you will need to put a resistor on tractor or get right coil ive done this by mistake it cracked coil cause it got so hot
  [Reply]  [No Email]
2-banger
01-22-2013 17:53:48
69.205.113.95
Re: JD 50 Electronic Ignition Coil Temp. in reply to 2-banger, 01-22-2013 17:51:44
jd didnt use risistor til the 20 series...20 and 30s use a 1.5 ohm coil they have resistor behind dash
  [Reply]  [No Email]
buickanddeere
01-22-2013 21:56:58
216.183.156.197
Re: JD 50 Electronic Ignition Coil Temp. in reply to 2-banger, 01-22-2013 17:53:48
How certain of that are you?
  [Reply]  [No Email]
M-MAN
01-14-2013 21:44:22
184.39.41.190
No experience with a flame thrower but all the coil's I've seen that were very hot had the wrong voltage & were fixing to go BOOM.
  [Reply]  [No Email]
buickanddeere
01-14-2013 18:31:20
184.151.63.164
Measure the coil current. Odds are it's closer to 8 amps than 4 which it should be.
What resistance between the coil primaries?
  [Reply]  [No Email]
Texasmark1
01-15-2013 05:41:48
198.45.243.137
Re: JD 50 Electronic Ignition Coil Temp. in reply to buickanddeere, 01-14-2013 18:31:20
Or measure the primary dc resistance (may be easier) which should be adequate to privide the 4-5 amperes that you want for your transistor switch to conduct. Taking a nominal 12v and 4 amps you need at least 3 ohms of dc resistance between the power applied from the ignition switch and the coil terminal that goes to the electronic ignition module. If you don't have it, get a ballast resistor in the circuit that will get you there.
Did you get instructions for installation, like a note that says that an xyz ohm ballast resistor is required with this coil?
Some ign. modules warn you that if you over current the circuit, which you seem to be doing, you can kill the module due to overheating the switching transistor.
  [Reply]  [No Email]
HobbySaw
01-15-2013 15:23:16
98.88.14.49
Re: JD 50 Electronic Ignition Coil Temp. in reply to Texasmark1, 01-15-2013 05:41:48
Now the rest of the story! So I learn this history today, the tractor hasn't been run much in 8 - 10 years. They never could keep it going for long, now I find out (with you fellows help) someone back "then" rewired the tractor - without the resistor! Now to replace it--- any suggestions? What would work that I can get from the auto parts store?
  [Reply]  [No Email]
Texasmark1
01-16-2013 05:44:39
198.45.243.137
Re: JD 50 Electronic Ignition Coil Temp. in reply to HobbySaw, 01-15-2013 15:23:16
Over the years I have needed resistors and purchased them from NAPA auto stores. Main thing is that it is made for the occasion with some being one value like 1.5 ohms or thereabouts, and others with taps where you could add resistance to get what you want. Then they are mounted on white ceramic bases to insulate them from their mounting since they get hot with 2 holes for mounting.
Mark
  [Reply]  [No Email]
buickanddeere
01-15-2013 16:12:04
216.183.149.205
Does the starter switch have the terminal for bypass starting.
Don't let anybody tell you that there really is a resistor inside some coils.
Do you want a tractor with bypass starting?
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
