| Author |
[Modern View]
| DanH
01-11-2013 17:09:02
97.32.99.10
Going to reinstall the head on my 620. What is the proper torque on the head bolts and what is the proper torque pattern. |
| 55deere70
01-12-2013 17:25:30
75.138.191.254
Re: Reinstall head on 620 in reply to DanH, 01-11-2013 17:09:02
| I can't find a JD service manual for 70 gas. To my knowledge, none were printed. |
| Gene Hillman
01-12-2013 06:21:06
38.114.76.109
| It's always a good idea to do the torquing three times by thirds. If the final torque is 150 ft. lbs. then do 50 all around, 100 all around and 150 final. This brings the casting down gradually |
| Pete in MD
01-11-2013 19:03:39
108.15.125.149
| Mr. Thinker's Almanac says 150# for the heads on 620/630s. |
| tractorbafoon
01-11-2013 17:58:35
216.188.210.45
| 175lbs of torque, start from the center and work your way out clockwise, then do it again, run the tractor and get it warmed up for a good hour or so, then retorque them, |
| buickanddeere
01-11-2013 17:22:29
216.183.138.71
| Nothing beats having a real service manual in hand for these and many other specs. 1-800-522-7448 . |
| kj@junction
01-12-2013 16:46:00
75.81.232.26
Re: Reinstall head on 620 in reply to buickanddeere, 01-11-2013 17:22:29
| B & D I had a 620 for a short time and mother deere had no manuals for it. I wanted mine for light work but it had some issues that IT didn't address I asked for some advice one here got blown off guess what I found a guy that wanted one to retore and actually made 50 bucks off it. |
| buickanddeere
01-12-2013 17:41:54
216.183.136.201
Re: Reinstall head on 620 in reply to kj@junction, 01-12-2013 16:46:00
| I doubt if anybody intended to blow you off. There are some mooches that want all the info free and easy, won't purchase a service manual. Don't have a whole lot of time for them. The 60 service manual will be sufficient. |
| Wilamayb
01-12-2013 05:58:09
71.15.150.66
| | There was never a SM produced for the 620/630. The substitute would be the 60 which is fairly different, or the 720 which is also pretty different. I'm totally agree that a guy needs a set of manuals for every piece of equipment that he owns, but in this instant it is not possible. The only way this info could be gathered would be from service bulletins. You can't get those @ 800-522-7448. Btw. The quality of Deere manuals leaves much to be desired. The paper is thin, printing is smudged and the price is silly. Why not suggest these two cylinder and new gen guys to buy their manuals from an aftermarket place that actually strives for quality? Some how these aftermarket folks are able to make clearly printed manuals on thick paper for half the cost of Deere. It's a no-brainer. |
| Handsome Jim
01-12-2013 09:48:02
99.195.150.205
Re: Reinstall head on 620 in reply to Wilamayb, 01-12-2013 05:58:09
| I bought one of those re-production IT manuals for a MT from the dealer. Had more info on Bs & As than vertical engines. |
| buickanddeere
01-12-2013 11:45:33
184.151.61.135
Re: Reinstall head on 620 in reply to Handsome Jim, 01-12-2013 09:48:02
| The IT makes a fine wrapper to keep grease off the JD service manual. Or to prop doors or windows open. The IT manual has just enough info to get some folk into trouble. |
| Wilamayb
01-12-2013 10:10:07
71.15.150.66
| | I'm not speaking of IT manuals but, rather of better reprints of the original manuals than Deere is willing to provide. I am in no way and advocate for IT manuals. |
| jdman(mo)
01-11-2013 19:46:41
64.49.150.124
| I wish they would made one for the 70 gas. |
