TractorLinks.com
Show Parts for Model:
Re: JD70 LP question
NEIADan
01-10-2013 19:17:22
It sounds like you are talking about the vaporizer. On the one side you have a diaghram that open and closes to match the vacuum of your intake. On the other side you have coolant circulating through a circular honeycomb and liquid propane in separate valley. The idea is to use the heat from the coolant to preheat the lp to a vapor in correlation with the diaghram of going from high pressure to a lower pressure in the intake providing the most vaporization of the lp. Those aluminum vaporizers are easily damaged allowing anti freeze to leak. often taking it apart and resurfacing the aluminum comb and plate with a new gasket and sealant it can be remedied.
JPFL
01-10-2013 19:26:18
 Re: JD70 LP question in reply to NEIADan, 01-10-2013 19:17:22
Thanks Dan, I will need to wait until manual comes. Jim
