Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 720 pony wiring
Toby Harter
01-10-2013 10:43:08
I think how it works is that blackdash models it was an oil light for indicating that the pony have oil pressure. For the models prior, the red light was to let you know that the key switch was still on. I might be wrong but somebody hopefully will chime in with more.
buck eye al
01-10-2013 14:21:14
 Re: 720 pony wiring in reply to Toby Harter, 01-10-2013 10:43:08
On the 70 D this lamp was on whenever the cranking ignition was switched on.
I believe the later 720's & 730's the lamp was on only when the cranking engine ignition switch is on but the cranking engine is not running! Once the cranking engine has oil pressure a pressure switch turns the lamp off. After the diesel is running and you turn off the fuel to the cranking engine letting it run out of gas & stop, the lamp comes back on to remind you to turn the ignition off. It's so easy to ignore and forget that lamp on the 70 that I've made it a habit to just NOT drive it until the cranking engine has stopped.
Copyright © 1997-2015 Yesterday's Tractor Co.
