Canadian Ken
pulley brake was loose on pivot and I need the friction pad for the brake
I found a shim that was the right size to take 90 percent of the play out of the brake and still allow the brake to operate
I took a brand new ABC187 clamp on pulley brake lining pad from Steiner's -removed the rivets from the steel backing plate
I cut 3/4 inch of the one end so that it fit
I drilled new holes in pad to match the brake frame hole pattern.
I used a flat wood bit to countersink the holes
I used 4 1/8" pop rivets to secure the pad to the brake frame
I ground the tops off the rivets down to the pins to clean thing up - I tried the operation -it seems to work good now -the real test will be when the tractor is running.
Ken
Ken
