TractorLinks.com
Show Parts for Model:
Re: hydraulic leak 4020
ET
01-08-2013 06:11:04
You will only loose whats in the oil cooler. If you let it set overnight there will be less. Is there a short hose from the elbo up to the oil cooler. I remember some power shifts that had 2 elbos on one side. One went to the oil cooler.
Tim S
01-08-2013 07:05:35
 Re: hydraulic leak 4020 in reply to ET, 01-08-2013 06:11:04
Try to wash it off good before you start to remove it, then run it to see if you can see for sure where the leak is,some times a fitting is suspect, but the leak may actually be above it and slobbering down to it,,on those it is very often the oil cooler leaking...you gonna have oil on the floor no matter what,,Darn it,,that"s why I buy floor dry by the skids...the guy at the parts store wanted to know if I was Feeding it....
centerplate
01-08-2013 20:20:19
 Re: hydraulic leak 4020 in reply to Tim S, 01-08-2013 07:05:35
Thanks for all the replies. I will dive into it next week.
