TractorLinks.com
Show Parts for Model:
Re: hydraulic leak 4020
ET
01-07-2013 09:02:19
There is an o-ring under the jam nut on the side of the pump. There could be a crack in the flare on the tube where it hooks on the elbo or the elbo itself may be cracked. Replacing the o-ring is where I would start.
centerplate
01-07-2013 12:03:39
 Re: hydraulic leak 4020 in reply to ET, 01-07-2013 09:02:19
I was not as clear in the description as I should have been. The leak appears to be on the elbow from the oil cooler. Can I drain that oil or is there a lot that will come out of the oil cooler? It is also a power shift tractor. There seems to be a different set up for the synchro-range.
ET
01-08-2013 06:11:04
 Re: hydraulic leak 4020 in reply to centerplate, 01-07-2013 12:03:39
You will only loose whats in the oil cooler. If you let it set overnight there will be less. Is there a short hose from the elbo up to the oil cooler. I remember some power shifts that had 2 elbos on one side. One went to the oil cooler.
Tim S
01-08-2013 07:05:35
 Re: hydraulic leak 4020 in reply to ET, 01-08-2013 06:11:04
Try to wash it off good before you start to remove it, then run it to see if you can see for sure where the leak is,some times a fitting is suspect, but the leak may actually be above it and slobbering down to it,,on those it is very often the oil cooler leaking...you gonna have oil on the floor no matter what,,Darn it,,that"s why I buy floor dry by the skids...the guy at the parts store wanted to know if I was Feeding it....
centerplate
01-08-2013 20:20:19
 Re: hydraulic leak 4020 in reply to Tim S, 01-08-2013 07:05:35
Thanks for all the replies. I will dive into it next week.
