| John Deere Tractors Discussion Forum |
Topic: 46 A fanshaft drive gear lube
[Return to Forum]
| Author |
[Modern View]
| Joe Btpfsplk
01-06-2013 19:13:03
99.101.173.181
my fanshaft gear is all chewed up looks like it was running dry. I cant find anything in the manual that shows how it gets lubed?...Anyone know??? |
| joe btpfsplk
01-07-2013 21:07:41
99.101.173.181
Re: 46 A fanshaft drive gear lube in reply to Joe Btpfsplk, 01-06-2013 19:13:03
| Thanks Ron...but still confused...(first time into a jd eng)looking thru fanshaft opening-can see the vertical hex shaped pc/w oil line connected @ bottom where do i go from there? |
| Lee B
01-08-2013 02:27:35
64.37.30.35
Re: 46 A fanshaft drive gear lube in reply to joe btpfsplk, 01-07-2013 21:07:41
| Wrong side to start from. Take off the oil gauge line from the back side of the governor case and remove any adapters going into the cast iron of the governor. Insert thin wire and poke around in the bottom of this passage dead center going forward. If you screw in a grease gun hose at this port and pump fast enough you can just blow it clean with high pressure grease too. The passage is much less than 1/16 inch in diameter, going straight forward and squirting oil directly on the gear. I drilled mine out to 1/16, don't think it caused any loss of oil pressure as measured on the gauge. To easily plugged when smaller in my opinion. |
| joe btpfsplk
01-08-2013 17:33:37
99.101.173.181
Re: 46 A fanshaft drive gear lube in reply to Lee B, 01-08-2013 02:27:35
| O.K. Thanks guys...thats just what i needed.like i said,inside of these eng. is all new territory for me. from the side i was looking at i could see a big gob of crud up there...bet thats the outlet! i agree, too small a hole...plugs too easy, especially when you see all the crud that comes out the first time you pull the drain plug! Anyone know the best place to get the gear set for this? I tried YT, they don't have it. |
| Lee B
01-10-2013 21:39:34
64.37.30.36
Re: 46 A fanshaft drive gear lube in reply to joe btpfsplk, 01-08-2013 17:33:37
| | Unfortunately $800 or close to from mother deere or used pair from local junk yard for cheaper if you can live with the wear on them. I swear they are so high I think I'll go into business making them myself for $500. |
| greenmech
01-06-2013 19:43:53
50.124.208.122
| Inside the gauge port there is a small spray hole that lubes the governor and gears. It is directly straight back and to the left side. A small wire bent 90 degrees will open it up. Ron Mn. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
