TractorLinks.com
Show Parts for Model:
Re: Live pump pessure rating
algar
01-03-2013 19:47:00
I have a 48 A I don't have a live pump at the moment but I would like to know what they are capable of in psi and GPM.I thought they were all the same. I could run it seperate from the powertrol unit. Will it run a 45 loader as good as the pto pump? they were below 1000 psi
Iwas hoping for more out of the live pump
Pete in MD
01-04-2013 08:02:44
 Re: Live pump pessure rating in reply to algar, 01-03-2013 19:47:00
A live pump on an A has a rated working pressure of 610 PSI and a GPM of 10.4 at zero pressure and 8.9 at rated working pressure. The two pumps are about the same.
If you run the live pump seperate from the powertrol unit you"ll need to add a reservoir and a control valve.
I think the live pump will run a 45 loader just as good as the pto pump AND you"ll be able to raise the loader when the clutch is disengaged.
MEANJDK
01-04-2013 05:18:21
algar, you can plumb your tractor to run the powertrol and your 45 loader separate without using a live hydraulic pump. I have one plumbed into the powertrol and use a back blade and a 45 loader for moving snow. Email if you would like more info. thanks, Jim.
