Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: JD60 Ballast Resistor
vvfarms
01-03-2013 11:52:21
John T the JD 2 cyl.from waterloo tractors with by-pass starting had 3 wires on coil. By-pass from starter switch went to coil side of resistor.(minor detail) Also all LP tractors had by-pass starting.When JD saw how good by-pass worked on LP's then they put it on rest of tractors.
gunther9
01-03-2013 15:33:13
 Re: JD60 Ballast Resistor in reply to vvfarms, 01-03-2013 11:52:21
John made an excellent point about the coil being hot whenever the starter is engaged even with the switch off. How does the three wire system wire up to prevent that? The wiring diagram I have shows the ballast resistor with three wires to coil and it looks like the coil is hot when the starter is engaged.
Copyright © 1997-2015 Yesterday's Tractor Co.
