| John Deere Tractors Discussion Forum |
Topic: How can this be happening?
[Return to Forum]
| Author |
[Modern View]
| Hugh McKinney
01-02-2013 11:32:50
72.161.82.36
I reinstalled the Delco generator on my 1955 70 L.P., and I'm still getting the kinks out of everything. The ignition switch is missing so I temporarily ran a hot wire from the negative post of the battery to the coil/distributor and voltage regulator. Everything works just fine, battery charges, starts easily. My question: before I reinstalled the generator, if I disconnected the hot wire from the battery, the engine went dead. Now, it keeps running, so to shut it off I have to shut off the fuel. No problem, but why does this work with my setup, but on any other motor vehicle I have owned, if you don't have voltage coming in from the battery, the engine dies, charging system or no charging system. Just wonderin'.... |
[Reply] [No Email] | |
| vvfarms
01-03-2013 11:17:22
50.33.200.137
Re: How can this be happening? in reply to Hugh McKinney, 01-02-2013 11:32:50
| Remember that tractor has a 6V coil & starter by- pass to improve starting,even though it is 12V. |
| rickdeere
01-02-2013 15:13:36
67.231.40.38
| You must put a diode in line. |
| old
01-02-2013 21:54:17
209.86.226.32
Re: How can this be happening? in reply to rickdeere, 01-02-2013 15:13:36
| Diode on a generator system???? Yes with an alternator but I have never in the 10 plus years heard of a diode on a generator system from any body on this site. From what he said he has the V.R. and the ignition wired together which is not correct |
| old
01-02-2013 13:40:48
4.244.81.182
| You have it hooked up in such a way that your not powering down the generator but you are unhooking the ignition from the battery but not form the generator system and by doing it that way the generator is still producing voltage so it keeps the ignition system powered up. Be careful because having it that way you can/will get a nasty shock that can in fact cause you harm and if you have a heart condition maybe kill you |
| Hugh McKinney
01-03-2013 07:48:49
72.161.82.36
Re: How can this be happening? in reply to old, 01-02-2013 13:40:48
| Well said, and point taken. Does anybody have a wiring diagram concerning voltage reg, generator, and ignition switch? I of course need to buy all the related manuals, but Christmas wiped out all the $ for a while. But thanks to all for the input, including the warning about voltage and cardiac arrest, it is a timely and relevant point. Hugh |
| old
01-03-2013 15:37:56
209.86.226.34
Re: How can this be happening? in reply to Hugh McKinney, 01-03-2013 07:48:49
| The fact that it can hurt you is not something that is likely to happen but all it takes is less then 100Th of an amp to kill and a generator puts out 35 plus amps so yep many time more then enough to kill if you did get hooked up in a wrong way. I prefer to warn a people of something that is not likely to happen then to have it happen |
| Tx Jim
01-03-2013 09:16:09
67.142.163.24
| Quoting Removed, click Modern View to see
Found this wiring diagram on this forum by using search function at the top of this page.
| Hugh McKinney
01-03-2013 19:50:43
99.197.160.57
Re: How can this be happening? in reply to Tx Jim, 01-03-2013 09:16:09
| This is a big help, thanks! |
| donarcher
01-02-2013 12:40:45
71.189.6.105
| It is runnig off of generator voltage.So you have to wire it correctly. |
| machinery-man
01-02-2013 12:10:37
98.93.72.12
| Sounds like your guessing at a wiring diagram....why no rewire like factor settings. I don't have the diagram but a parts manual, service manual would. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
