JD60 Ballast Resistor
gunther9
Does anyone know where the ignition ballast resistor was located shipped from the factory? There's a ballast resistor on the ignition/light switch but after checking switch operation with an ohmeter I'm sure that resistor drops voltage to the front headlights when the switch is in the D(im) position.
The JD A and the first number series which includes the 60 DON"T have a ballast resistor as delivered from the factory. Both the A and 60 us a true 12 volt coil. There may have been later service bulletins converting the 60 to a bypass ignition system as on the 520 and 620 etc. Conversion would entail a resistor, a 6 volt coil, a diffrent starter switch, and a bypass wire from the starter switch to the negative side of the coil.
If a ballast is used on a 60, you must also have a 6 volt coil otherwise you will have weak spark.
It had a 6V coil with a ballast resistor mounted to the coil. Ugly. I don't know how it came from the factory. It's a later model 60 #6061643 so I assumed it was built with a 6V/ballast setup but I'm not sure.
So If you have a 60 with a 12 volt battery, you want to run wire from switch through a resister and into a 6 volt coil? What if you buy a coil with a resister built in? You would want a 6 volt coil with internal resister and that would work fine as well?
Gunther, I dont think your tractor had a ballast resistor (sure it could have, never say never, I saw all sorts of modifications in my many years as a used tractor dealer) Its a 12 volt tractor that used a 12 volt coil therefore NO BALLAST REQUIRED. If you used a 12 volt coil PLUS a ballast, the spark would be weak.
On 12 volt tractors (like the later 620 and 720 etc) that used a ballast resistor THATS BECAUSE THEY USED A 6 VOLT COIL and the ballast dropped 6 volts leaving 6 for the 6 volt coil WELL DUHHHHHHHH
NOTE: A 12 volt coil is typically labeled "12 volts" orrrrrrr "12 volts NOT for use with ballast" orrrrrrrrrr "12 volts NO ballast required"
NORE: Theres a misconception out there that some 12 volt old tractor coils have a stand alone ResisTOR inside the can WRONGGGGGGGGGGGGG
Contrary to what many lay persons believe who call them coils that have an "internal ballast resistor" YOU WILL NOTTTTTTTTTTTT FIND A DISCRETE STAND ALONE RESIS"TOR" TUCKED AWAY SOMEWHERE INSIDE THE CAN. The way a "12 volt" coil achieves its necessary 3 or so ohms of LV primary resistANCE is by enough wire coil length (more wire or more coil turns) orrrrrrrrr using wire with certain resistANCE per unit length so the ResistANCE end to end (+ to -) ends up in the range of 2.5 to 4 or so ohms so the points dont burn up and the coil doesnt overheat and handles the current when 12 volts is applied.
SORRY CHARLIE, DONT DISECT ONE AND EXPECT TO FIND A STAND ALONE "RESISTOR" HIDDEN INSIDE
NOTE they actually did make some very early automotive coils that DID HAVE a stand alone discrete ResisTOR in a seperate part of the can!! Many had like a ring where the internal can portions were seperated, coil in one end resisTOR in other end all by itslef!! HOWEVER in alllllll my years as a used tractor dealer (older tractors) I never saw a coil with such an internal resisTOR inside the can!!!!!!!!
Hope this helps, post back any questions
Best wishes and God Bless
John T
4010:
YOUR QUESTION: So If you have a 60 with a 12 volt battery, you want to run wire from switch through a resister and into a 6 volt coil?
ANSWER: You could if you like!!!!!!! or else simpler to just use a 12 volt coil that way you dont have the wiring worry and extra connections and expense of a then un needed ballast!!!
YOUR QUESTION: If you buy a coil with a resister built in? You would want a 6 volt coil with internal resister and that would work fine as well?
ANSWER: SEE MY POST ABOVE, YOURE NOT GONNA FIND A COIL THAT HAS A STAND ALONE DISCRETE RESISTOR TUCKED AWAY SOMEWHERE INSIDE THE CAN
HOWEVER, You CAN FIND a "12 volt" coil orrrrrrrrr a coil labeled "12 volts NOT for use with ballast" orrrrr a coil labeled "12 volts NO ballast required" AND GUESS WHAT they are engineered and designed to operate at 12 volts nominal and like they say NO BALLAST REQUIRED
ALSO you can buy a coil labeled "6 volts" orrrrrrrr "12 volts FOR USE WITH ballast resistor" orrrrrr "12 volts requires ballast" AND GUESS WHAT!!! THOSE ARE ALL IN REALITY 6 VOLT COILS
SOOOOOOO on a 12 volt tractor you can use EITHER
a) A 12 volt coil
orrrrrrrrrrrrrrrrrrrrrrr
b) A 6 volt coil PLUSSSSSSS an external series voltage dropping (12 to 6) ballast resistor
Get it???? Its NOT really rocket science, post back any questions, hope this answers your great questions
best wishes and God Bless
John T
Usually (like on the later 620) the ballast was mounted on the back of the steering pedestal, NOT on the coil HOWEVER in all my years of used tractor dealership I SAW ABOUT EVERYTHING LOL
NOTE; A reason for using the 6 volt coil on a 12 volt tractor was to improve cold weather starting, but the tractor had to have the ballast by pass circuit/system to make that work ya know !!!!!!!! The later 620 etc had such
Hope this helps, best wishes n God Bless, fun discussion
John T
Thanks everyone for the input. I bought this tractor in September 2012 and it had the 6V coil with the ballast resistor. I haven't had the flywheel cover off yet so I don't know if the starter has the terminal to shoot 12V directly to the coil or not. If not, I may get a switch with the side terminal keep the 6V coil and set it up for the 12V kick when starting.
John T,
At serial number 6043000 according to the parts book they started using the bypass ignition and resistor like the 620 and 630 tractors.
Rich
That starter switch with the extra little terminal to send unballasted battery voltage to the coil ONLY WHILE CRANKING (ballast by pass system to improve cold weather starting) is a simple and easy fix if its not already so equipped. The wire goes from there to the coils high INPUT (from ballast and NOT to distributor) terminal.
CAUTION NOTE (a lot of laymen and rookies MISS this safety feature) on the 20 series tractors that used the ballast by pass system the ignition switch has an extra terminal Mag/Ground and it wires down to the coils low output (to distributor) terminal for safety BECAUSE without it when you step on the starter even if Ign is off, the engine ignition is HOTTTTTTTTTTT
Thats why on the 20 series theres 4 wires on the coil, 2 on input (from ballast and to startrer switch), 2 on output (1 to distributor one to ign switch Mag/Ground)
John T
Cool, thats why I NEVER SAY NEVER as I posted, great info, Books are a help sometimes !!!!!!!!
John T
Youre welcome, it could save someones life even, yet many many gents out there arent aware of the safety problem nor aware how to fix it!!
John T
John T the JD 2 cyl.from waterloo tractors with by-pass starting had 3 wires on coil. By-pass from starter switch went to coil side of resistor.(minor detail) Also all LP tractors had by-pass starting.When JD saw how good by-pass worked on LP's then they put it on rest of tractors.
John made an excellent point about the coil being hot whenever the starter is engaged even with the switch off. How does the three wire system wire up to prevent that? The wiring diagram I have shows the ballast resistor with three wires to coil and it looks like the coil is hot when the starter is engaged.
