| John Deere Tractors Discussion Forum |
Topic: Wet sleeve removal on JD 1120
[Return to Forum]
| Author |
[Modern View]
| Winger Ed.
01-01-2013 20:14:21
68.95.248.149
I've gleened alot of info. here, but never really had anything to contribute. Here's something I hadn't seen or heard of before that might help somebody later on down the road: Recently I had to pull the sleeves to rebuild the 3 cylinders on a late '60's JD 1120 Diesel. These didn't just jump out when removing the pistons.
Not having the tool, or able to take it to a shop, I was at the head scratching stage when I got a idea-- that worked. I put a floor jack under the engine, set a oak board with a block of Lead on it reaching up through/around/past the crankshaft. I put pressure on the jack, making sure the only contact inside the block was the Lead tipped board under the edge of the protruding cylinder sleeve. With a Brass block on top of the cylinder sleeve, and not touching the top/deck of the Iron block, start tapping around the edge. Be real careful and tap firmly with a hammer. The impact of the hammer only touches the top edge of the sleeve. It takes awhile, I spent about 20-30 minutes per cylinder; but the pressure and vibration will pop the sleeve. You're not trying to pound the sleeve out, just get vibrations going in it like what you feel if you ring a bell and then touch it. The weight of the tractor on the jack will let the sleeve drift out from the bottom. |
| buickanddeere
01-02-2013 06:59:39
184.151.61.148
Re: Wet sleeve removal on JD 1120 in reply to Winger Ed., 01-01-2013 20:14:21
| Sounds like you are trying to get by with an in frame over haul. Pull the cam and followers and replace the cam bearings. Either return the followers only to the lobes they previously rode on. Or better yet a cam and follower re-grind is cheap. Use the highest compression piston/sleeve set that Deere sells. Take a good look at the oil pump and gears. Toss them in the junk if wear is found. |
| Tech 7
01-02-2013 05:26:17
206.47.90.66
| Glad it worked for you...I have used a similar technique myself as our shop doesn't have the proper puller.It is surprising what a bit of sludge/crud can do to help the O rings bite the sleeves. I have had the front wheels of 4430's coming off the floor before adding a bit of vibration to ease things along. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
