TractorLinks.com
Show Parts for Model:
Re: Belt pulley seal for late B question
Carlyle Hoffman
12-30-2012 13:42:15
A plug ed oil return is one issue , but look for blow by one cyl or the other, or maybe the ventilator pump is not working. Place a playing card over the crank case oil in let and if it does not draw it down you have a problem. You will also see blow by there too.
gtx1967jewison
12-30-2012 21:04:34
 Re: Belt pulley seal for late B question in reply to Carlyle Hoffman, 12-30-2012 13:42:15
I believe the vent pump actually pressurizes the crankcase, not a vacuum. The pump takes air from the air cleaner into the crankcase. Air then leaves the valve cover & enters the intake pipe just before the carb. That pipe could be plugged. Also if the drain hole is working in the cover it can. Probably run without rings and still not leak. I have an A with SEVERE blowby & 25# compression & the clutch side dont leak.
