855 JD Tractor
Anonymous-0
Tractor is a hydro, 4wd. Will move frt & back but
will not pull any thing, grinds in rear end. Not
sure where to start.
It's possible something has failed in one of the pinion gears(parts keys 32-36) or shafts in the differential. Have you tried engaging diff lock to see if tractor will briefly move a load? Also possibly a broken rear axle.
