Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: John Deere 40 Clutch replacement
[Return to Forum]
jared brady eldridge
12-28-2012 13:28:28
98.95.113.79
I am restoring my first antique tractor and had was wondering whether or not it was necessary to change out the pressure plate whenever I change out the clutch. AS of right now the clutch is working fine, but I was planning on replacing it whenever I changed out the rear seal that is leaking so that I don't have to break the tractor down again anytime soon. Is it recommended to change out the pressure plate as well when doing this.
Thanks,
Brady
[Reply]   [No Email]
Jcarroll
12-29-2012 14:48:11
75.14.15.130
Re: John Deere 40 Clutch replacement in reply to jared brady eldridge, 12-28-2012 13:28:28
New throw out bearing. Check wear on the mechanism, now is the time to make it "new".
  [Reply]  [No Email]
Dave H
12-29-2012 13:42:10
66.116.18.234
I would do like MikeM. No one will know if it is "new" or not in there.
When I had my 420 apart umpteen years ago I put a used clutch disc in there.
It is still working like new.
  [Reply]  [No Email]
Larry Baker
12-28-2012 20:02:57
204.116.154.116
Jared
It has been my experience on the dubq. to also go ahead and change the imput shaft seal and check it for wear.Dont know how many you see sitting pretty with the same leak,you've done got it into may as well go one more time.One more issue to check while you got its pants down is the splines on the shaft that runs from the clutch to the transmission,some of them the splines are almost gone,just some stuff I learned while attending University of Hard Knocks
  [Reply]  [No Email]
LarrySTN
12-28-2012 15:48:41
69.68.35.50
Since the clutch works the way it should now, I would inspect the clutch and pressure plate as Mike says, checking finger height before removing pressure plate. And as Mike says if the disk looks good reuse it also. There are many back to the field work horse tractors that have had the pressure plate reused without issue.
  [Reply]  [No Email]
Bob Harvey
12-28-2012 15:06:07
209.121.225.193
For the time involved, I would replace EVERYTHING in the clutch. Pressure plate, disc, release brg.(if applicable) and pilot brg (if applicable). Also the transmission seal (if applicable). Unlikely you would ever have any problems or have to 'go back in' because something failed or made a noise. HTH
  [Reply]  [No Email]
Mike M
12-28-2012 13:42:01
24.140.0.120
If it's still a good smooth flat surface and the pivot points or end of the levers look good I would reuse it. Your disk may even be good too ?
I'd check the finger height before tear down and see if they are all the same. Not sure if the book give a spec. or not ?
  [Reply]  [No Email]
LarrySTN
12-28-2012 15:50:05
69.68.35.50
Re: John Deere 40 Clutch replacement in reply to Mike M, 12-28-2012 13:42:01
Mike, I've seen in the past that your in central Ohio? Are your near Wooster?
  [Reply]  [No Email]
Mike M
12-29-2012 07:51:21
184.20.169.244
Re: John Deere 40 Clutch replacement in reply to LarrySTN, 12-28-2012 15:50:05
Work in wooster and live in Ashland Co.
  [Reply]  [No Email]
LarrySTN
12-29-2012 10:49:49
69.68.35.50
Re: John Deere 40 Clutch replacement in reply to Mike M, 12-29-2012 07:51:21
Did you used to work in parts at the john deere dealer that was on 250?
  [Reply]  [No Email]
Mike M
12-29-2012 20:07:04
184.20.169.244
Re: John Deere 40 Clutch replacement in reply to LarrySTN, 12-29-2012 10:49:49
Yes. If you live in Orrville area then I'm sure we know each other.
  [Reply]  [No Email]
LarrySTN
12-29-2012 22:28:57
69.68.35.50
Re: John Deere 40 Clutch replacement in reply to Mike M, 12-29-2012 20:07:04
yes, I'm near Orrville.
  [Reply]  [No Email]
Brady Eldridge
12-30-2012 09:04:39
96.19.165.169
Re: John Deere 40 Clutch replacement in reply to LarrySTN, 12-29-2012 22:28:57
Thanks for all the information
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
