diesel in oil 4320
larryanderson
A fellow called with nice 4320 said it gets small amount of diesel fuel in oil.I had it happen on a truck several years ago and it had to do with injection pump .Any input? thanks
The lift pump, then the injector pump drive shaft seal, with a possibility of the return fitting clogging a bit creating back pressure to the shaft seal..
Thanks, guys... My 2510 is getting diesel in the oil. Changed the fuel filter last spring and the plunger on the take-up pump did not work. Had to take off the bleeder and pour fuel in to fill the filter. Bet that's the problem. Adds about a quart of fuel to the crankcase every 10-13 hours, so I change it often.
Lift pump can't pump fuel if cam lobe is putting pressure on lift pump operating arm. Engine must be rotated a little to get cam lobe away from pump arm so pump can pump fuel.
