TractorLinks.com
Show Parts for Model:
Re: Using old John Deere's 0n snow blowers
gtx1967jewison
12-27-2012 05:47:07
Why not? Well....
I would turn up the fuel & make sure it runs @ rated speed or slightly more. If your pto is good & blower is not huge it should work fine, but youll need live pto cuz the reverse is WAYYY too fast (lotsa clutch wear)
BushogPapa
12-27-2012 15:34:39
 Re: Using old John Deere's 0n snow blowers in reply to gtx1967jewison, 12-27-2012 05:47:07
m I agree with giving it a little "head-Room" of increased RPM...but, they don't pull down until there is way too much load in the 1st place...
If it were a 70 GAS, I would say..give it a Couple-a-hundred RPM increase...they do not have any head-Room to pull down at 975....
Ron..
Dan in Ohio
12-27-2012 07:14:09
Good point, did not think about that fast reverse. Have never used the PTO on any of my old tractors. May have to look into putting one on this little guy.
Photobucket
algar
12-27-2012 15:58:37
 Re: Using old John Deere's 0n snow blowers in reply to Dan in Ohio, 12-27-2012 07:14:09
absolutely on that,I have one on a old 322 hydro works great no slipping the clutch
Mike M
12-27-2012 08:03:03
Put one on the front of that one !!!! tire chains too and I'll bet you can run circles around that old 70 and your neighbor.
Tim S
12-27-2012 08:10:49
 Re: Using old John Deere's 0n snow blowers in reply to Mike M, 12-27-2012 08:03:03
Yes Mike that little Hydrostatic would work out good, a blower on the front end is the better way, A couple years ago I was working on an idea to run mine on the front shaft of the 2510, was gonna make a drop case to get under the oil pan to get the power to it,,but the sun came out and the ideas went away with the snow...
Mike M
12-27-2012 10:44:08
 Re: Using old John Deere's 0n snow blowers in reply to Tim S, 12-27-2012 08:10:49
I think I saw on this site ? pictures where someone was mounting old 3 point snow blowers on the front end loaders ( or maybe just frt ends ) and running them with a hyd. motor driven from a pto pump.
