Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 620s and 630s
BushogPapa
12-26-2012 11:44:32
Carefully Measure the Rt Main Bearing Clearance (with a Dial indicator)... If it has more than Specs, the oil-feed passage under the Rt Main bearing Quill may be blocked..and that also means the Rt Rod will be starving for oil too.. If the Transmission is over-full, it may be engine oil, from that Rt main/Seal, because of excessive bearing clearance..
Put a Load on the PTO and see if it engages or Slips.. Look at the oil in the PTO..it should be 10 Wt oil... If it is 90 Wt, the seal is out... Power Steering..?? Does it work easy both ways..?? Signs of Leaking..??
Intake/Exhaust manifold going bad..?? Gaskets out where it meets the Head on each side..?? (Requires pulling the Head and having it Machined)... Not uncommon for the Intake to be splitting, where the Heat-Crossover meets the intake.. Gauges work..?? Tires..?? Radiator..??
Make sure EVERY Gear is good...and the shifter feels secure and tight.. Would be best to put a Load on it in each gear, actually..
Sheet Metal decent, or beat up..?
All the usual things as well..
Ron..
RMOMN
12-26-2012 14:35:49
 Re: 620s and 630s in reply to BushogPapa, 12-26-2012 11:44:32
Thanks Ron this is exactly what I'm looking for
BushogPapa
12-26-2012 20:10:49
 Re: 620s and 630s in reply to RMOMN, 12-26-2012 14:35:49
The ONE thing you will notice with the 620/630 Series tractors is the very Large increase in "Felt or apparent Power", over the Letter and 60 Series..and the TRUE 3-Point with Load/Depth Control..(Very Nice to have)... Put one "in good shape" and you should not need to again in this Lifetime...!! The Hand clutch on a 620/630 may seem a little grabby, if not in use for a while, but will settle to a very predictable, easy to use control..
Ron..
