49 jdeere bearings
Anonymous-0
rebuilding 49ao jdeere. normally read manuel,started with rear axle seals and bearings looked so simple did not read. bearings looked good so i cleaned and repacked, by luck got long axle on right side, then short on left, got axle work done and every thing seemed to turn ok.looking at parts manuel after the fact noticed there is left and right axle, then looked at axle bearings and i have doubt about what i put in or how to interpet parts book mine has turning brakes. could all bearing be same?
thanks
According to the parts manual, the axle is the only part shown as left and right. All bearings and seals are shown as 2 used, or 4 used. Should not be a problem.
thanks i have axles, bearings,seals and gears in place and all seems ok, i just had doubts which i seem to have more often.
