TractorLinks.com
Show Parts for Model:
Re: Pony motor for 70D
buickanddeere
12-22-2012 04:45:33
Your pretty well have it. Two working coils with ignition wires that match. A spring wire and a post coil doesn't work together any better than a spring coil and a post wire. Autolite 437 plugs work well. Gap is in the operators manual. I've dialed in more timing advance on those engines and they work better. As previously stated there could be 58 years worth of ick stuck between the fuel tank and the carb jet. The hose can fail internally too. There is a fuel transfer tube with a slotted head on the side of the carb. Spin it out and make sure somebody didn't twist it off thinking it was a mixture adjustment. Float level is critical.. Ensure the starting engine water pump seal is good.
