Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: power steering cam
grandpajohn
12-21-2012 20:16:19
forgot the pic
WTW
12-21-2012 20:43:08
 Re: power steering cam in reply to grandpajohn, 12-21-2012 20:16:19
GPJohn,
The grooves in cams have to be the same width. Depending on which actuating sleeve you have, will determine the cams you need to use. There is two different actuating sleeves that have different size dowel pins that these cam anchor to. Both pins in a given actuating sleeve are the same diameter/size. I usually also replace the pins as they too will be worn. Hope this helps, DW
Copyright © 1997-2015 Yesterday's Tractor Co.
