Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: 4020 Excite Resistor
[Show Entire Topic]  [Return to Forum]
Mike in Nebraska
12-21-2012 06:12:15
75.88.97.174
Its a 67 so it was 24v. It was converted with a Deere kit. It is a Delco 10SI three wire. I've tried alternators off of other tractors and the problem stays with this tractor.
[Reply]   [No Email]
Heat Houser
12-21-2012 14:38:01
192.43.65.245
Re: 4020 Excite Resistor in reply to Mike in Nebraska, 12-21-2012 06:12:15
Delco 10SI
Batt to switch to one leg of the charge light. The other leg of the charge light to Pin 1 on the alternator. This circuit needs to be switched for if not, your light will always burn as it is grounded thru R5 in the regulator. This will drain your battery.
When charging
Alternator output from the diode trio is fed into the circuit between the light and R5. This output is more than R5 can dissipate so voltage rises. Via pin one and the wiring, as this voltage rises, it finally becomes equal to battery voltage. Once this occurs, you have equal voltage on both sides of the light and it goes out. Equal voltages means no electron flow.
BTW, once the alternator starts to produce, it becomes self exciting via the diode trio.
Take a digital volt meter and watch if battery voltage steadly climbs after starting. It will bump up by a tenth of a volt or so as the batt is recharged. It should finally settle out at the regulator's voltage setting as it becomes fully charged. If it does this, you have a wiring problem, not an alternator problem.
  [Reply]  [No Email]
Heat Houser
12-21-2012 14:46:54
192.43.65.245
Re: 4020 Excite Resistor in reply to Heat Houser, 12-21-2012 14:38:01
BTW, you need batt voltage in on pin 2 as this is where the zeiner diode gets its signal from. The ZD controls the base of transistor 2 and transistor 2 controls the base of transistor 1. Transistor 1 controls the field circuit. Diode trio, to brush, to slip ring, to field coil, to other slip ring, to transistor 1, to ground.
  [Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
