i got a 4010 i just rerplaced the crank in,now it wont start,iv got crank and cam timed with its marks,tdc line in center of window,oil pump lined up right,front piston at top dead center,and then valves closed,pretty much timed,but tractor wont start,there was a newly rebuilt injector pump just redone by a man with 40 years expierence,but it wont start up,it smokes blue meanuing timing could be off,but i cant see nothing off unless the wrong piston is at tdc,anyone know where i went wrong?tractor was running perfect till i tried this fresh pump,and no air in system either,but will fire off with ether
also where is the best place to start off at timing?id the numbers above tdc the top numbers and the numbers below btdc?
