TractorLinks.com
Show Parts for Model:
Re: 4850 trans?
1963
12-08-2012 15:19:14
It runs fine in 15th gear until you throttle down and then hit the throttle again. Loses about 3 mph and the engine seems to labor and in about 3-5 minutes the hyd oil temp light comes on along with the ? and eventually the stop alarm.
Tim S
12-08-2012 16:18:30
 Re: 4850 trans? in reply to 1963, 12-08-2012 15:19:14
It"s possible that low trans pressure is causing the alarm to go off,low pressure can cause a slow shift letting one clutch stay on a bit longer or one "not" engaging quick enough. warm it up and do some pressure checks to see what kind of trans pressure you have,,another possibility is a clutch can be warped and dragging too...B&D is right deal with it now and the cost may be minor...it will only get worse....
buickanddeere
12-08-2012 15:27:22
Don't keep operating the tractor in any gear. A moderate priced repair will be very expensive.
