Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Hey F-I-T or buickanddeere
F-I-T
12-07-2012 19:35:30
The RH main is oiled by the crankshaft drilled oil holes. Once you have the PTO gear off, the oil seal can be clawed out without removing the main bearing housing. If you think it is leaking around the main, the housing can slide out, but you may have to support the crank to keep things in line as you slide it off to replace the gasket. Could be it is just loose...
