Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 720D cylinders firing unevenly when not under load
richardinnz
12-07-2012 14:12:09
....."It doesn"t use oil, but would it explain it if I was losing compression on a cylinder after it warms up?"
I have been caught out on this before ,no,or normal oil consumption after keeping oil-v-fuel used records for a period of 100hrs or more.
Your oil control rings may be fine, but you can get this loss of compression with out increased oil consumption. Carry out dry and wet compression tests when the engine is hot. You won"t need to know what the correct compression should be,It is not a new tractor and there will be wear in the engine, what you are looking for is a difference in pressures between the two pots, more than around 10% between them and you need to be looking for trouble. If you get a difference you will need to carry out a wet test in case you have a compression loss through a valve or valves
Do your testing after checking the valve clearances, and pull the air inlet pipe off the inlet manifold. Test must be done engine hot. If all is o.k there then you can turn your attention to the fuel system which may need to be done by a Diesel injection specialist knowing that the base engine is satisfactory.
