TractorLinks.com
Show Parts for Model:
Re: 720D cylinders firing unevenly when not under load
buickanddeere
12-07-2012 10:16:58
There is a procedure in the service manual to time and balance the pumps. Is one side of the cylinder head, just below the port. Warmer or cooler than the other?
kssheets
12-07-2012 18:26:41
 Re: 720D cylinders firing unevenly when not under load in reply to buickanddeere, 12-07-2012 10:16:58
Thanks all for the suggestions. I"ve tried to feel for a temp difference between cylinders just to know which one wasn"t hitting hard, but couldn"t tell. Will need to bring an IR gun home and check. Will run through the pump timing and balancing, and try opening the fuel lines to see which side is weak.
I just hope it isn"t a compression issue... thanks guys
