TractorLinks.com
Show Parts for Model:
Re: 3020 3pt hyd valve overhaul
farmero2
12-07-2012 04:54:57
My 3020 is a side console and has no cable. Rods activate the lever. I have larger tires on the 3000 diesel from a 4400. The first final drive broke in a wierd way, the hub split in a circle around the bolt holes, so the wheel never fell off but the the axle hub actually spun inside the wheel bolt circle. Second one from Keiters lasted one week in corn and came apart at the retaining nut on the inside of the shaft. That happened on the black top road. For the third one I took parts from each of the broken ones and was able to repair a drve. Same problem again on this one, the nut worked loose on the inside and out came the axle, again it broke on the highway. Local towing outfit now knows how to haul combines on a boom. I am now afraid to drive the diesel. There seems to be a big difference in gear ratios between the gasser and the diesel, the gasser will run circles around the diesel.
tomstractorsandtoys1
12-07-2012 07:21:04
 Re: 3020 3pt hyd valve overhaul in reply to farmero2, 12-07-2012 04:54:57
My Dads 3300 did the same thing many years ago on the road,not fun blocking up ad fixing.Sorry you had to pay so much for parts as here in the midwest $1000 will buy a fairly good 3300 combine(gas).Most seem to be going to scrape or a combine derby to be destroyed.Good machines in there day except for the counter shaft under the grain tank.I helped rebuild Dads twice and one or two on neighbors as well.
farmero2
12-07-2012 14:08:04
 Re: 3020 3pt hyd valve overhaul in reply to tomstractorsandtoys1, 12-07-2012 07:21:04
I look at the western combines on the internet and say, GEE that is cheap. If only shipping was not so expensive I could have a newer combine.
Tx Jim
12-08-2012 03:46:41
 Re: 3020 3pt hyd valve overhaul in reply to farmero2, 12-07-2012 14:08:04
Here's the 2 o-rings because I'll bet the torch did them in.
parts key # 14 R394R PACKING, O-RING ADD 1.22 USD
parts key # 16 U13639 PACKING, O-RING ADD 3.25 USD
Tx Jim
12-07-2012 05:10:27
OK since I now know it's a 3020 SN >123,000 I'll regroup. Check the big nut(parts key #15 or 24) for tightness as they have a history of loosening over time and affecting 3pt operation plus leaking oil. The following parts are for R&R of valve body if required to correct oil leak.
R40896 GASKET ADD 6.84 USD
2ea R27166 PACKING O RING ADD 1.22 USD 2.44 USD
This post was edited by Tx Jim at 05:15:24 12/07/12 2 times.
farmero2
12-07-2012 14:03:10
 Re: 3020 3pt hyd valve overhaul in reply to Tx Jim, 12-07-2012 05:10:27
Looks like I have parts 13 and 15 for the control lever. If 13 is brass colored then that is what I have. Parts 13 and 15 were frozen together so could not move the lever. I put heat to the big nut and got the lever moving. I quess now I should take it apart and see if I hurt the O rings. Otherwise it looks OK but the bottom gasket was no good. Thanks.
