TractorLinks.com
Show Parts for Model:
Re: BD Grand National
jddriver
12-06-2012 19:33:29
still has the v6 turbo but has an air to air also>I did not know they had that.Trans appears to be alum No rust on body nad 14in wheels?mOUSE NEST IN AIR CLEANER THE INTERIOR DOES NOT STINK U THINK THESE CARS are worth saving this one is all there except the auto It looks fast setting there with 4 flats
buickanddeere
12-07-2012 06:45:42
 Re: BD Grand National in reply to jddriver, 12-06-2012 19:33:29
All 86 and 87's had the air to air intercooler mounted between the rad and the water pump. Cool air from a scoop below the coolant rad. A small crank mounted fan moved some air through the intercooler. There is a modified factor intercooler that is "Stretched" lower/longer and has the improved outlet. Still have the factory chrome steel rims with the turbo6 design? Somebody went to a lot of work to swap in a clutch , a BOP pattern belhousing and a transmission that could handle the torque. A beefed up TH200R4 is faster and reliable. Needs the hardened stator support, larger servo pistons, larger 2nd gear band, front pump upgrade, pressure regulator valve upgrade, extra clutch packs and a few other tweaks. Will handle a 500+HP turbo as long as some knob doesn't rev the engine then yank the trans into gear.
jddriver
12-07-2012 18:43:12
 Re: BD Grand National in reply to buickanddeere, 12-07-2012 06:45:42
wheels are very dingy but it looks like a 6? in the middle ? Tires are comppletely rotten seats prob need recovered
