Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: BD Grand National
buickanddeere
12-06-2012 07:26:45
What is under the hood? Did somebody transplant a Vette drive train in there? Turbo's work better with an automatic. The turbo can be spooled up by brake torquing the converter. The turbo rpms stat up during gear shifts.
jddriver
12-06-2012 19:33:29
 Re: BD Grand National in reply to buickanddeere, 12-06-2012 07:26:45
still has the v6 turbo but has an air to air also>I did not know they had that.Trans appears to be alum No rust on body nad 14in wheels?mOUSE NEST IN AIR CLEANER THE INTERIOR DOES NOT STINK U THINK THESE CARS are worth saving this one is all there except the auto It looks fast setting there with 4 flats
buickanddeere
12-07-2012 06:45:42
 Re: BD Grand National in reply to jddriver, 12-06-2012 19:33:29
All 86 and 87's had the air to air intercooler mounted between the rad and the water pump. Cool air from a scoop below the coolant rad. A small crank mounted fan moved some air through the intercooler. There is a modified factor intercooler that is "Stretched" lower/longer and has the improved outlet. Still have the factory chrome steel rims with the turbo6 design? Somebody went to a lot of work to swap in a clutch , a BOP pattern belhousing and a transmission that could handle the torque. A beefed up TH200R4 is faster and reliable. Needs the hardened stator support, larger servo pistons, larger 2nd gear band, front pump upgrade, pressure regulator valve upgrade, extra clutch packs and a few other tweaks. Will handle a 500+HP turbo as long as some knob doesn't rev the engine then yank the trans into gear.
jddriver
12-07-2012 18:43:12
 Re: BD Grand National in reply to buickanddeere, 12-07-2012 06:45:42
wheels are very dingy but it looks like a 6? in the middle ? Tires are comppletely rotten seats prob need recovered
