TractorLinks.com
Show Parts for Model:
Re: Old 531/619 any relation to the new 12.5 ?
JDBert
12-05-2012 06:30:46
The 10.1 was the liter designation of the 619- the 12.5 is a clean slate motor- electronically controlled.
Kent Petersen
12-05-2012 11:53:28
 Re: Old 531/619 any relation to the new 12.5 ? in reply to JDBert, 12-05-2012 06:30:46
no reltive at all other then green paint the 10.1 and 12.5 are totaly differant from the 619.look a lot like 60 series detroit
FactoryFarmer
12-05-2012 14:54:43
 Re: Old 531/619 any relation to the new 12.5 ? in reply to Kent Petersen, 12-05-2012 11:53:28
Thats because it kind of is to a point :lol:
Eric Hartman
12-05-2012 18:10:31
 Re: Old 531/619 any relation to the new 12.5 ? in reply to FactoryFarmer, 12-05-2012 14:54:43
I had a conversation with a John Deere representative at the time the 9000 series four wheel drive tractors were introduced. As I recall, the 9100 had the 8.1 liter engine, the 9200 had the 10.5 liter engine, and the 9300 and 9400 both had the 12.5 liter engine. The 10.5 liter was discontinued not long after the introduction. In my conversation with the JD rep, he had indicated Detroit Diesel and JD Power formed some sort of a joint venture in diesel engine development, and after he said this, I recall reading that back in the early to mid 1980's. The 10.5 and 12.5 liter Deere engines came out that joint effort, and the 60 series Detroit also came out of that joint venture. If I remember correctly, the first two 60 series Detroits were 11.1 liter and 12.7 liter displacement engines. I managed to acquire a JD power brochure on the 10.5 and 12.5 liter engines, and also the brochures on the 60 series Detroits when they were introduced. It has been some time since I have looked at either one, but I would agree they look very similar, as they were jointly developed and engineered by John Deere and Detroit Diesel. This joint effort, or venture, was ultimately discontinued. Some of my reading indicates the two wanted to develop a basic engine design together that could utilize newly developing and common fuel management systems being worked on by Bosch. If you do an internet search, there is some interesting reading about these engines and some on the joint efforts. I remember talking with the first truck owner/operators who switched from Cat or Cummins powered trucks to the new 60 series Detroits and they indicated there was a definite edge in fuel mileage as compared to what they were accustomed to with their prior power plants.
DEEREMEYER1
12-06-2012 09:11:21
 Re: Old 531/619 any relation to the new 12.5 ? in reply to Eric Hartman, 12-05-2012 18:10:31
I've heard that story several times, and I don't know if it's true or not. A Caterpillar E-model looks a lot like the Deere and Detroit engines too when you get right down to it. Any 6-cylinder, 4-valve, OHC, EUI diesel is going to look pretty much like another since there's not much room for innovation there. I've even been told by a so-called "expert" that Detroit and Deere valve covers interchange, which is complete b.s.
Eric Hartman
12-06-2012 15:21:55
 Re: Old 531/619 any relation to the new 12.5 ? in reply to DEEREMEYER1, 12-06-2012 09:11:21
Well, I do remember back in about 1983,1984, or 1985, an article mentioning the joint venture or joint effort of Deere and Detroit. Might have been in Farm Industry News or another farm publication.
buickanddeere
12-05-2012 07:29:30
Kind of surprised that there was never a mechanical pump equipped Tier I or II engine in the 10.5L or 12.5L ? The later 13.5L maybe was only an electronic engine?
DEEREMEYER1
12-05-2012 10:29:52
 Re: Old 531/619 any relation to the new 12.5 ? in reply to buickanddeere, 12-05-2012 07:29:30
The 10.5 and 12.5 have been EUI (electronic unit injector) equipped from the get-go, and also have overhead camshafts. The blocks actually look a little similar to late 7.6. It's a pretty small block relative to the displacement, but obviously moving the camshaft to the cylinder head allows for more bore and especially stroke relative to the size of the block. Good engines all the way around. I did have to go through one awhile back that had water pump bearing balls go through the timing gears. Not good. Got it all back together and had an oil leak. When the balls went through it shoved the camshaft up hard enough to crack the front cam bearing bore. So, it got torn down completely and rebuilt with a reman cylinder head.
Tim S
12-05-2012 10:42:17
 Re: Old 531/619 any relation to the new 12.5 ? in reply to DEEREMEYER1, 12-05-2012 10:29:52
There is nothing good about a cam shaft driven water pump,,a bad idea from the start..
DEEREMEYER1
12-06-2012 09:05:37
 Re: Old 531/619 any relation to the new 12.5 ? in reply to Tim S, 12-05-2012 10:42:17
I'm not a big fan, but a lot of engines use them and have for a long time.
Tx Jim
12-05-2012 11:45:56
Come on Tim admit it that if alternator belts break water pump keeps on pumping water. Seriously I hate the camshaft driven water pump on my 4255. I've already found antifreeze in the crankcase once.
