TractorLinks.com
Show Parts for Model:
Re: 4230 electrical question
Tim S
12-04-2012 18:45:50
Check the connections at the circuit breakers, they corrode there under the nuts.Then make sure that the switch is being fed on Batt. A and Batt. B terminal.
Tx Jim
12-05-2012 03:55:40
 Re: 4230 electrical question in reply to Tim S, 12-04-2012 18:45:50
Tim
I agree on checking ALL connections on the circuit breaker board on the LH side in front of the dash as they've had a long history of loose connections. I don't remember "4230's" having battery A & B as I was thinking they utilized two 6 volt batteries attached in series. I was also thinking there are some hard to access light relays under dash above the diff lock pedal.
Tim S
12-05-2012 04:09:33
 Re: 4230 electrical question in reply to Tx Jim, 12-05-2012 03:55:40
There are 2 power feeds to the light switch, both 12 volt and same polarity, it helps spread the load by using 2 terminals, if one loses power it will affect part of the lights.
