Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: dltx10 problems
PopinJohn
12-04-2012 18:10:30
The engine should die with the idle mixture screw closed. If the passages in the carburetor are clean, the tractor should run at WOT with the idle mixture about 1-1/4 to 1-1/2 turns open.
The IDLE mixture adjustment does not mean idle RPM.
It means "unloaded" at any RPM, and should be open enough to stop governor surging at WOT, but not open enough to give black smoke.
However, adjusting at WOT may be too rich at slow RPM, so,your final setting may be a compromise between top and slow RPM setting.
Engine should be warmed up pretty good for adjusting.
On most B's, the load needle will be right at 3/4 to one turn out.
MikeS.
Sam Vastano
12-05-2012 07:13:06
 Re: dltx10 problems in reply to PopinJohn, 12-04-2012 18:10:30
Long shot but what about the plug wires???
