Unstyled B Radiator Disassembly
Anonymous-0
Got my 36 B running, but the radiator leaks around the core like a sprinkling can. Most of the upper & lower tank bolts on the out side look good. It's the straps on the back side of the core, inside the shroud that are severely rusty. Are these studs, bolts, capscrews or what?? Any advise as to how to take this apart without damageing the tanks? Suggestions please?
Those are capscrews. Might try heating them up 1st before trying to remove. But they will probably still break.
I did mine about a year ago and I heated them and put a candle near them before I tried to loosen them. The candle wax gets sucked into the threads acting like a lubricant and I only broke one.
Hope this helps!
Sam
