Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: gas tank leak
Roger in Michigan
12-04-2012 15:34:41
Thanks, B-maniac.
But I think it's above where the bowl screws into the tank. It's the thing that comes directly out of the tank that is leaking--between the metal of the tank and the part that comes out and receives the top of the bowl. I don't think that screws in. Any ideas?
F-I-T
12-04-2012 16:31:52
 Re: gas tank leak in reply to Roger in Michigan, 12-04-2012 15:34:41
Clean it up well, and de-fume it with a good detergent washing, then re-solder the bung with a copper.
Roger in Michigan
12-04-2012 16:51:53
 Re: gas tank leak in reply to F-I-T, 12-04-2012 16:31:52
Thanks, F.I.T. I'll try that. A little more work than I had hoped. Have to take the tank off.
Bob Harvey
12-04-2012 20:46:48
 Re: gas tank leak in reply to Roger in Michigan, 12-04-2012 16:51:53
Probably not a bad idea to put the tank on some blocks to put the 'to be soldered' area 'up' and fill the tank with as much water as possible up to (below) the 'to be soldered' point. Residual gas can make a nasty FAWHOOMPH !! HTH
Copyright © 1997-2015 Yesterday's Tractor Co.
