Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: JD B problem
[Show Entire Topic]  [Return to Forum]
Doug Sr.
12-02-2012 15:39:58
99.195.64.111
You may have broke or stuck piston rings.
Doug
[Reply]   [No Email]
JCrutt
12-02-2012 19:41:31
67.142.177.22
 Re: JD B problem in reply to Doug Sr., 12-02-2012 15:39:58
Doug, I considered that but the good power has lead me to put that idea on back burner for now.
Thanks for the imput. Basic mechanical tests and inspections show good. As diesel mechanic is why it has me stumped and I realy don't understand how the vent pump is supposed to work. I want to cover everything else before I do a tear down. I've never seen a 2cyl do this.
[Reply]  [No Email]
F-I-T
12-02-2012 19:49:20
184.6.247.3
 Re: JD B problem in reply to JCrutt, 12-02-2012 19:41:31
JCrutt said: (quoted from post at 20:41:31 12/02/12) Doug, I considered that but the good power has lead me to put that idea on back burner for now.
You ought to get a current hot compression check as well, in case the cylinder that is in not too good shape is really worse than you think.
The vent pump sits at the base of the fanshaft, governor end, and depending on the model year, is either a rotary vane or roller pump, so it pushes air into the crankcase anytime the engine is turning and the fan is spinning. Depending on the model year...and I'm guessing on your S/N, clean air is drawn from the air cleaner down the fanshaft tube, pumped into the governor, to the crankcase, and it crawls forward to the valve cover, where it is exhausted via pipe to the carb intake elbow to re-burn any nasty fumes. Later models had a separate inlet pipe.
Had an "A" one time the pump vane seized, as many do, and it would suck gobs of oil into the carb. Quick fix was to drill a small hole in the side of the fill pipe nipple until you could get around to pulling the fanshaft.
This post was edited by F-I-T at 19:58:02 12/02/12 2 times.
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
