| John Deere Tractors Discussion Forum |
Topic: JD B problem
[Return to Forum]
| Author |
[Modern View]
| JCrutt
12-02-2012 14:48:44
67.142.177.23
My 1950 JD B Poof"s out smoke by the clutch and blows valve cover gasket out at the same time. All vents have been removed and cleaned, it"s getting very annoying. Run"s great. Looking for idea"s. Ventilator pump issue? |
| JCrutt
12-02-2012 18:59:10
67.142.177.23
Re: JD B problem in reply to JCrutt, 12-02-2012 14:48:44
| I always shut gas off. I will perform that check. I do have a weak cylinder that leaks a little oil when I open peck cocks, and she does smoke lightly. But I have seen others like this and don"t have this problem. It will do it even when I leave fill cap loose. It runs so good is what has me stumped. I can win slow trator races every time. And even tho they are close in HP it gives my Brothern laws 50 a run for it"s money pulling. We take turns beating each other at tractor pull"s. One of the gutiest B"s I have ever worked. |
| Mark-Ia
12-02-2012 17:38:16
207.177.117.7
| Does it have gas in the oil? |
| F-I-T
12-02-2012 15:53:42
184.6.247.3
| JCrutt said: (quoted from post at 15:48:44 12/02/12) My 1950 JD B Poof"s out smoke by the clutch and blows valve cover gasket out at the same time. All vents have been removed and cleaned, it"s getting very annoying. Run"s great. Looking for idea"s. Ventilator pump issue? |
Sorry, I got interrupted, so I'll edit my typos now...
Could be that the vent pump is not working properly, and that is allowing fuel vapors to collect in the crankcase, and a poof that is strong enough to blow the valve cover gasket out of position is actually an explosion.
Take the oil fill cap off and lay a playing card over the pipe. If it sucks down a bit, the pump is working. Keep your face away in case she poofs while you are testing.
This post was edited by F-I-T at 19:11:58 12/02/12. |
| JCrutt
12-02-2012 19:32:04
67.142.177.22
Re: JD B problem in reply to F-I-T, 12-02-2012 15:53:42
| Ok thanks I will ck that. I wondered how to test it. |
| Doug Sr.
12-02-2012 15:39:58
99.195.64.111
| You may have broke or stuck piston rings. Doug |
| JCrutt
12-02-2012 19:41:31
67.142.177.22
Re: JD B problem in reply to Doug Sr., 12-02-2012 15:39:58
| Doug, I considered that but the good power has lead me to put that idea on back burner for now. Thanks for the imput. Basic mechanical tests and inspections show good. As diesel mechanic is why it has me stumped and I realy don't understand how the vent pump is supposed to work. I want to cover everything else before I do a tear down. I've never seen a 2cyl do this. |
| F-I-T
12-02-2012 19:49:20
184.6.247.3
Re: JD B problem in reply to JCrutt, 12-02-2012 19:41:31
JCrutt said: (quoted from post at 20:41:31 12/02/12) Doug, I considered that but the good power has lead me to put that idea on back burner for now.
You ought to get a current hot compression check as well, in case the cylinder that is in not too good shape is really worse than you think.
The vent pump sits at the base of the fanshaft, governor end, and depending on the model year, is either a rotary vane or roller pump, so it pushes air into the crankcase anytime the engine is turning and the fan is spinning. Depending on the model year...and I'm guessing on your S/N, clean air is drawn from the air cleaner down the fanshaft tube, pumped into the governor, to the crankcase, and it crawls forward to the valve cover, where it is exhausted via pipe to the carb intake elbow to re-burn any nasty fumes. Later models had a separate inlet pipe.
Had an "A" one time the pump vane seized, as many do, and it would suck gobs of oil into the carb. Quick fix was to drill a small hole in the side of the fill pipe nipple until you could get around to pulling the fanshaft.
This post was edited by F-I-T at 19:58:02 12/02/12 2 times. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
