TractorLinks.com
Show Parts for Model:
Re: 70 axle seal
F-I-T
12-02-2012 12:06:56
Not really. The axle seal is located at the INSIDE end of the axle, so you go in through the back, remove the bull gear and replace seal. Now, if you have the axle housing filled with a lot of oil, it will continue to drip unless you mop that oil out of there because the "seal" on the outer end is just a felt meant to keep dust out of the greased bearing. Some folks dril a hole through the lower inner axle housing stud to make a drip point to clear the housing, then put the stud back in to seal it again. Never tried that myself, just mopped out the housing.
