Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 4020 joy stick loader
buickanddeere
12-02-2012 11:25:13
Check for flow when the loader control valve is in neutral. Odds are the joystick valve is either open centre, failed an o'ring or has a relief valve set below 2400psi.
Tx Jim
12-02-2012 11:49:04
 Re: 4020 joy stick loader in reply to buickanddeere, 12-02-2012 11:25:13
b&d pretty much summed it up. Disconnect the return hose and with JS in neutral no oil should flow out return hose with engine running.
Steve Keller
12-02-2012 12:10:58
 Re: 4020 joy stick loader in reply to Tx Jim, 12-02-2012 11:49:04
Thanks, I will do just that. I used a new Prince 25 gpm loader valve that is naturally open but is sold with a plug that i thought was supposed to make it closed. I ordered it that way and the plug was installed before delivery. Also I looked it up and the preset relief is at 2000 psi but can be set up to 3000. Should I make that change before checking the flow?
MSM
12-02-2012 12:31:35
 Re: 4020 joy stick loader in reply to Steve Keller, 12-02-2012 12:10:58
Set the relief first, if it is opening at 2000 psi on a 2250-2400psi system there is your problem. With it bleeding off pressure the tractor will crank slow and your loader functions will be slow
Steve Keller
12-02-2012 12:41:50
 Re: 4020 joy stick loader in reply to MSM, 12-02-2012 12:31:35
Thanks again for the help.
Copyright © 1997-2015 Yesterday's Tractor Co.
