| John Deere Tractors Discussion Forum |
Topic: 2520 axle mount duals
[Return to Forum]
| Author |
[Modern View]
| larryanderson
12-02-2012 04:10:20
184.21.172.50
I have a guy with a mint 2520 that wants to add JD 9 bolt duals.I have some wheels and have a set of wedge style hubs and was wondering if wedges out of an original casting will work.I dont have a 2520 here right now so what size axle wedges out of what tractor would work?I havent had any wedges smaller than 3/1/8 and I remember they being smaller.Thanks |
| Mike Aylward
12-02-2012 10:58:09
216.145.134.145
Re: 2520 axle mount duals in reply to larryanderson, 12-02-2012 04:10:20
| Larry, you will have to do some looking in the parts books. The 2 7/8" axle was used clear back to the model 50 through the 520 and 530. I believe some early 4030's also used this size axle. It may be possible to use the axle wedges from any of the older tractors in the hubs you may have. The taper angle of these hubs was changed at some point so compare the hub casting number with a wheel casting number, such as the common F1500R. Many of those wedges will work in the earlier dual hubs. The later hubs that may have the different taper angle would require a later (and harder to find) wheel wedge. It can be done and has been but you need to be a good student of the parts books. Mike |
| Bob Bancroft
12-02-2012 06:05:23
97.73.64.144
| I just went out and measured the 2520, and 2510 while I was at it. They are the same. Yes, they are 2 7/8" axles. You might get about 8" of axle at the most if the wheels are rolled way in. A little more if you removed the push bolts. I suppose the whole effort would be easier with tires narrower than 15.5. I was thinking the same thing, but ended up with wide spaced clamp on duals, spaced for 30" rows. |
| TD
12-02-2012 05:13:32
97.107.61.113
| I believe the 2520 has 2 7/8 size axle, and if the tractor has the extra long axles they would be the 3 1/8 size axle. |
| Tx Jim
12-02-2012 04:39:28
67.142.163.27
| Does 2520 have regular or long axles?? These are the wedges PC lists for 2520 which also fit a 4000.
B3014R PINION 1
A4379R PINION 1 (3.05M (120") TREAD)
B3018R BUSHING 1
R32224 HALF SLEEVE 1 (3.05M (120") TREAD) |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
