Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 70 manifold valve
F-I-T
11-29-2012 20:00:40
Yes, I have. Several times. I like to heat them in a good soaking wood fire if I have the manifold off, and then I let them cool down in the ashes, since the ashes have a lot of phosphate in them, and that acts as sort of a soap. It gets in everywhere. Once it is cooled to ambient, I lay the manifold on a good flat surface, and give the valve a whack on the flats with a pretty stout hammer. The valve is tapered so you have to knock them down to get them loose. The whacking with the hammer is even published in the Field Service Bullettins. The FSB says to whack it when it's on the head.
jdman(mo)
11-29-2012 20:18:48
 Re: 70 manifold valve in reply to F-I-T, 11-29-2012 20:00:40
Thanks, I have tried soaking, hot tank, I guess it would be unwise to use a rosebud. To bad I just burned my brush pile, got pretty hot melted glass Also where do you find that acid for cleaning gas tanks? Russ
F-I-T
11-29-2012 20:21:10
 Re: 70 manifold valve in reply to jdman(mo), 11-29-2012 20:18:48
jdman(mo) said: (quoted from post at 21:18:48 11/29/12) Thanks, I have tried soaking, hot tank, I guess it would be unwise to use a rosebud. To bad I just burned my brush pile, got pretty hot melted glass Also where do you find that acid for cleaning gas tanks? Russ
Go look at the link below for some pictures, but I find it at Home Depot and Lowe's all the time.
If you could remove the manifold, I would try a rosebud, but it's risky on the tractor.
[img]http://ytforums.ytmag.com/viewtopic.php?t=965833[/img]
This post was edited by F-I-T at 20:26:49 11/29/12.
Dave in SV
11-30-2012 15:00:58
 Re: 70 manifold valve in reply to F-I-T, 11-29-2012 20:21:10
What"s a rosebud? Answer ONLY if you aint gonna yell at me! LOL
55deere70
11-30-2012 15:11:58
 Re: 70 manifold valve in reply to Dave in SV, 11-30-2012 15:00:58
A heating tip for an oxy acetylene torch.
jdman(mo)
11-29-2012 20:24:45
Everything from the pedestal fwd is off. its just a skeleton. Give it a try. Russ
F-I-T
11-29-2012 20:34:21
 Re: 70 manifold valve in reply to jdman(mo), 11-29-2012 20:24:45
I'd lay it on a bed of dry kitty litter so it doesn't heat soak a cool spot on a corner and crack. It will cool nice and slow on the kitty litter, too.
