Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 4020 sychro adjustment
[Return to Forum]
Roger in Iowa
11-29-2012 14:21:47
166.182.3.106
I know I have read solution but cannot find it.
1970 4020 sychro, overshifts in the higher gear of the range, i.e. 3, 5, 7 and 8. All work, but just have to carefully get it in the above gears. 5, 7 and 8 worse but have learned to not shift it so far downward on these gears.
Have cover off for other reasons so now is the time to fix.
Thanks for help.
[Reply]   [No Email]
Tim S
11-30-2012 05:21:17
68.75.23.93
Re: 4020 sychro adjustment in reply to Roger in Iowa, 11-29-2012 14:21:47
Put new bushings, clevis and pins,shims in the upper shifter to start with, the adjustments is basically centering the shifter in each gear. Also I have seen the shifter pivot pin get loose and wear the hole a bit, when this happens I pean the hole to "swell" it enough to hold the pin, then goob it up with some JB weld to fill in the void them tighten it up good and let it set for a day. This works fairly good most of the time, but only if you swell the hole first and then depend on the JB weld to finish the fit...And if this don"t solve the problem get the splitting stands out.....
  [Reply]  [No Email]
tomstractorsandtoys1
11-30-2012 07:04:45
64.136.27.164
Re: 4020 sychro adjustment in reply to Tim S, 11-30-2012 05:21:17
Tim have you ever replaced the pointers behind the plugs on the side of the trans that go against the cams? We replace them with a ball and retainer like the later 4230's used,it seems to help center the cam better as many are wore bad from the pointer.We also replace the springs.
  [Reply]  [No Email]
Tim S
11-30-2012 07:34:54
68.75.23.93
Re: 4020 sychro adjustment in reply to tomstractorsandtoys1, 11-30-2012 07:04:45
Yes when I re-build a transmission I include those with the parts, every little bit helps, but "most" of the time a shift problem is worn sychronizers...
  [Reply]  [No Email]
Tx Jim
11-30-2012 04:19:45
67.142.163.24
Roger is there very much side to side movement in the shift quadrants in the dash?? If so it needs to be shimmed.
  [Reply]  [No Email]
Jim Knapp
11-29-2012 14:35:34
184.20.33.131
Might just be the clevises on the shifter rods from the shifter under the dash to the transmission.
Jim
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
