Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: no oil pressure
Josh cartey
11-28-2012 11:21:41
I have looked at it and it appears to be a broken coupler. Looks to be cracked looking through the crankcase cover. Bout to tear it apart to fix. Thanks for the help everyone! It's been quite a few years since I worked on one. Just needed a little refreshing.
rickdeere
11-28-2012 11:35:51
 Re: no oil pressure in reply to Josh cartey, 11-28-2012 11:21:41
no problem to drop pump and put another coupler on but you might need a helper.cant be under tractor and on top at samwe time.
F-I-T
11-28-2012 11:27:04
Josh, depending on the temperature, it could have broken because excessive water in the oil. Ice can break those couplers which act as sort of a "fuse" so that you don't do other damage. Check for water/ice in that pump when you drain it.
Copyright © 1997-2015 Yesterday's Tractor Co.
