TractorLinks.com
Show Parts for Model:
Re: no oil pressure
Fredsjdb
11-27-2012 15:58:43
Josh, when I bought my 50 A it had no oil pressure. I checked the coupler and it was still intact. I found someone overtightened the oil filter cover nut breaking the oil pressure regulator housing that is located on top of the filter canister. If this is your problem it can be fixed without tearing to much of the tractor up. It's not a fun job. You"ll have to locate a replacement oil pressure regulator and probably a new stud. Check to see if you can remove the filter cover, if it just spins that"s a good indication the oil pressure regulator has been broken. Good luck. Fred
rickdeere
11-28-2012 07:46:28
 Re: no oil pressure in reply to Fredsjdb, 11-27-2012 15:58:43
When I replace canister top on my b I had to pull the entire block so I could have room to work, A,s are some bigger.
