Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Confused on Model of Plow.....
Carlyle Hoffman
11-27-2012 10:42:19
In your photo, that hole right above the land wheel tire in that lift link is for a transport pin, it goes into the frame hole ajaysent to it. Had a little anti loss chain originally . As for the tail wheel, there was a optional 4 bolt rim 15" to give more height and still plow .Any 15" or 16" JD 4 bolt rim should mount the hub.That described PIN , was also installed in the link for PLOWING.
11-27-2012 14:30:18
 Re: Confused on Model of Plow..... in reply to Carlyle Hoffman, 11-27-2012 10:42:19
The 15" tail wheel was an option on the F610, F620 plows. But I believe you will need to also replace the rear axle and hub. The small wheel hub is 3 bolt and the 15" wheel requires a 4 bolt hub. Also, the axle is longer to provide clearance for the 15" wheel. Attached is a picture of my F620 plow with the 15" wheel. Al
