720 Diesel Radiator neck
The radiator neck on my 720 was replaced at some point with one that sticks way up (3 inches up) above the hood line. How would one go about replacing that monster with a correct one? Are there correct ones out there without the entire top tank attached? There is nothing wrong with the radiator, just that ugly neck. Thanks
Walk in peace
Sounds like it has a 730 neck or maybe someone swapped the whole thing at one point ?
I'd check the casting numbers and make sure they match up for a 720 first then I'd get the right neck and put it in if the tanks were correct.
