Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
4720 wont start after roll-over
Are Johnsn
11-24-2012 07:22:36
Long story short, the tractor had a very slow roll over, we got it righted and now it won't start. There is oil in the pan and plenty diesel.
I tried priming the diesel filter to remove any air. The engine turns over but won't start. Any thoughts.... I don't see any other damage than a hazard light. The tractor was probably on its right side with the engine angled downward to upside down for about 2 hours...
Tx Jim
11-24-2012 09:12:25
 Re: 4720 wont start after roll-over in reply to Are Johnsn, 11-24-2012 07:22:36
I could be wrong but I think if some oil drained past the piston rings while tractor was over-turned then it's possible while attempting to start engine some push rods or valves could have gotten bent.
This post was edited by Tx Jim at 09:14:17 11/24/12.
Are Johnsen
11-24-2012 09:49:07
 Re: 4720 wont start after roll-over in reply to Tx Jim, 11-24-2012 09:12:25
I thought that too. but the engine turns over quite easy...
Oil did spill out the vent tube however...
Mrjdman80
11-24-2012 08:02:42
do you hear the fuel solinoid clicking when you turn the key on? it should be a good loud snap.
Tim
Are Johnsn
11-24-2012 09:08:34
 Re: 4720 wont start after roll-over in reply to Mrjdman80, 11-24-2012 08:02:42
I just tried the ignition and I didn't hear the load click. I have always heard that click whenever I start. Is that coming from the fuel relay, K-1?
Mrjdman80
11-24-2012 10:03:51
 Re: 4720 wont start after roll-over in reply to Are Johnsn, 11-24-2012 09:08:34
the loud click is the solinoid itself. no click means no fuel. the wires are on the right front corner of the engine. those solinoids can get filled with oil and then they wont pull in
Tim
Copyright © 1997-2015 Yesterday's Tractor Co.
